Ir para o conteúdo principal
Disassembling Yamaha YPG-225 Faceplate
O que você precisa
  1. Disassembling Yamaha YPG-225 Faceplate, Batteries: passo 1, imagem 1 %32
    • Turn the keyboard over so that the keys are facing the ground.
  2. Disassembling Yamaha YPG-225 Faceplate: passo 2, imagem 1 %32
    • Pop the tabs on the battery casing and remove it from the back plate.
  3. Disassembling Yamaha YPG-225 Faceplate: passo 3, imagem 1 %32
    • Locate the six batteries and remove them from the battery cavity.
  4. Disassembling Yamaha YPG-225 Faceplate, Faceplate: passo 4, imagem 1 %32
    • Remove the six 10mm screws at the top of the backplate.
  5. Disassembling Yamaha YPG-225 Faceplate: passo 5, imagem 1 %32
    • Remove the seven 12mm screws in the middle of the back plate.
  6. Disassembling Yamaha YPG-225 Faceplate: passo 6, imagem 1 %32
    • Remove the eight 10mm screws from the side and the bottom of the back plate.
  7. Disassembling Yamaha YPG-225 Faceplate: passo 7, imagem 1 %32
    • As the face plate is no longer connected to the body of the keyboard, be careful to not drop the body when performing this step.
    • Flip over the keyboard.
  8. Disassembling Yamaha YPG-225 Faceplate: passo 8, imagem 1 %32 Disassembling Yamaha YPG-225 Faceplate: passo 8, imagem 2 %32
    • Lifting from the front and the back of the face plate equally, pull the face plate up and then back, away from the keyboard.
    • Be careful when removing the face plate. There are wires attached.
Conclusão
Lonnie Bissmeyer
Membro desde: 09/16/12
468 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 2-62, Propen Fall 2012 Membro de Cal Poly, Team 2-62, Propen Fall 2012
CPSU-PROPEN-F12S2G62
Membros da 2
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 10
Duração total: 1,716
