Ir para o conteúdo principal
Introdução
This guide is a prerequisite for replacing other parts of an Xbox 360 E.
Ferramentas
Peças
Nenhum componente especificado.
  1. Push the Spudger into the crevice between the grated top panel of the Xbox and the bottom body with the rubber feet.
    • Push the Spudger into the crevice between the grated top panel of the Xbox and the bottom body with the rubber feet.
    • Pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
  2. Slide the spudger along the separation you have created between the grated panel and the bottom body of the Xbox.
    • Slide the spudger along the separation you have created between the grated panel and the bottom body of the Xbox.
    • Periodically pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
  3. Continue sliding the spudger along the perimeter of the left grated face of the Xbox. Pull the top panel off. Pull the top panel off.
    • Continue sliding the spudger along the perimeter of the left grated face of the Xbox.
    • Pull the top panel off.
Conclusão
4 outras pessoas concluíram este guia.
Jennifer
Membro desde: 02/02/2014
1.768 Reputação
4 Guias de autoria
Equipe
Cal Poly, Team 2-11, Amido Winter 2014 Membro de Cal Poly, Team 2-11, Amido Winter 2014
CPSU-AMIDO-W14S2G11
4 Membros
31 Guias de autoria
Um comentário
I broke my spudger! May I use anything besides that?
Colin2 Schrek - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 28
Duração total: 1,767
