Ir para o conteúdo principal
Disassembling Xbox 360 E Top Panel
O que você precisa
  1. Disassembling Xbox 360 E Top Panel, Top Panel: passo 1, imagem 1 %32
    • Push the Spudger into the crevice between the grated top panel of the Xbox and the bottom body with the rubber feet.
    • Pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
  2. Disassembling Xbox 360 E Top Panel: passo 2, imagem 1 %32
    • Slide the spudger along the separation you have created between the grated panel and the bottom body of the Xbox.
    • Periodically pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
  3. Disassembling Xbox 360 E Top Panel: passo 3, imagem 1 %32 Disassembling Xbox 360 E Top Panel: passo 3, imagem 2 %32 Disassembling Xbox 360 E Top Panel: passo 3, imagem 3 %32
    • Continue sliding the spudger along the perimeter of the left grated face of the Xbox.
    • Pull the top panel off.
Conclusão
4 outras pessoas executaram este guia.
Jennifer
Membro desde: 02/02/14
2.079 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 2-11, Amido Winter 2014 Membro de Cal Poly, Team 2-11, Amido Winter 2014
CPSU-AMIDO-W14S2G11
4 Membros
Autoria de 44 guias
1Comentário do guia
I broke my spudger! May I use anything besides that?
Colin2 Schrek - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 32
Ao todo: 3,368
