Peças
Não são necessárias peças.
  1. Use a large plastic opening tool along the rear panel: There are 4 clips to release. There are 4 clips to release.
    • Use a large plastic opening tool along the rear panel:
      • There are 4 clips to release.
  2. Slide the cover along the plastic frame. Slide the cover along the plastic frame.
    • Slide the cover along the plastic frame.
  3. Slide off the largest plastic pieces.
    • Slide off the largest plastic pieces.
  4. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  5. Bend the second small plastic piece to release it from the rubber piece. Now you can slide it out. Now you can slide it out.
    • Bend the second small plastic piece to release it from the rubber piece.
    • Now you can slide it out.
  6. Slide out the hard drive as shown in the picture Make sure to slide as shown or you may damage the USB bridge logic board.
    • Slide out the hard drive as shown in the picture
    • Make sure to slide as shown or you may damage the USB bridge logic board.
  7. Remove the 4 rubber piece from the plastic frame at each corner. Remove the 4 rubber piece from the plastic frame at each corner.
    • Remove the 4 rubber piece from the plastic frame at each corner.
  8. Remove the rubber piece from the  SATA/USB bridge logic board.
    • Remove the rubber piece from the SATA/USB bridge logic board.
  9. Remove both screws holding the retaining plate and the hard drive. Slide the retaining plate in order to disconnect the SATA connector.
    • Remove both screws holding the retaining plate and the hard drive.
    • Slide the retaining plate in order to disconnect the SATA connector.
  10. Remove both screws holding the retaining plate with the logic board.
    • Remove both screws holding the retaining plate with the logic board.
Conclusão
Gaetan
9.337 reputação
18 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Todo: 1,386
