Ir para o conteúdo principal
Disassembling Western Digital Essentials HD LED Light conducting plastic pieces
O que você precisa
  1. Disassembling Western Digital Essentials HD LED Light conducting plastic pieces, Case: passo 1, imagem 1 %32 Disassembling Western Digital Essentials HD LED Light conducting plastic pieces, Case: passo 1, imagem 2 %32 Disassembling Western Digital Essentials HD LED Light conducting plastic pieces, Case: passo 1, imagem 3 %32
    • Use a large plastic opening tool along the rear panel:
    • There are 4 clips to release.
  2. Disassembling Western Digital Essentials HD LED Light conducting plastic pieces: passo 2, imagem 1 %32 Disassembling Western Digital Essentials HD LED Light conducting plastic pieces: passo 2, imagem 2 %32
    • Slide the cover along the plastic frame.
  3. Disassembling Western Digital Essentials HD LED Light conducting plastic pieces, LED Light conducting plastic pieces: passo 3, imagem 1 %32
    • Slide off the largest plastic pieces.
  4. Disassembling Western Digital Essentials HD LED Light conducting plastic pieces: passo 4, imagem 1 %32 Disassembling Western Digital Essentials HD LED Light conducting plastic pieces: passo 4, imagem 2 %32 Disassembling Western Digital Essentials HD LED Light conducting plastic pieces: passo 4, imagem 3 %32
    • Bend the second small plastic piece to release it from the rubber piece.
    • Now you can slide it out.
Conclusão
Gaetan
Membro desde: 12/26/12
9.574 Reputação
Autoria de 18 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 14
Duração total: 1,090
