Ir para o conteúdo principal
Disassembling Western Digital Essentials HD Anti-vibration rubber pieces
O que você precisa
  1. Disassembling Western Digital Essentials HD Anti-vibration rubber pieces, Case: passo 1, imagem 1 %32 Disassembling Western Digital Essentials HD Anti-vibration rubber pieces, Case: passo 1, imagem 2 %32 Disassembling Western Digital Essentials HD Anti-vibration rubber pieces, Case: passo 1, imagem 3 %32
    • Use a large plastic opening tool along the rear panel:
    • There are 4 clips to release.
  2. Disassembling Western Digital Essentials HD Anti-vibration rubber pieces: passo 2, imagem 1 %32 Disassembling Western Digital Essentials HD Anti-vibration rubber pieces: passo 2, imagem 2 %32
    • Slide the cover along the plastic frame.
  3. Disassembling Western Digital Essentials HD Anti-vibration rubber pieces, LED Light conducting plastic pieces: passo 3, imagem 1 %32
    • Slide off the largest plastic pieces.
  4. Disassembling Western Digital Essentials HD Anti-vibration rubber pieces: passo 4, imagem 1 %32 Disassembling Western Digital Essentials HD Anti-vibration rubber pieces: passo 4, imagem 2 %32 Disassembling Western Digital Essentials HD Anti-vibration rubber pieces: passo 4, imagem 3 %32
    • Bend the second small plastic piece to release it from the rubber piece.
    • Now you can slide it out.
  5. Disassembling Western Digital Essentials HD Anti-vibration rubber pieces, Disassembling Western Digital Essentials HD Hard Drive: passo 5, imagem 1 %32 Disassembling Western Digital Essentials HD Anti-vibration rubber pieces, Disassembling Western Digital Essentials HD Hard Drive: passo 5, imagem 2 %32
    • Slide out the hard drive as shown in the picture
    • Make sure to slide as shown or you may damage the USB bridge logic board.
  6. Disassembling Western Digital Essentials HD Anti-vibration rubber pieces, Disassembling Western Digital Essentials HD Anti-vibration rubber pieces: passo 6, imagem 1 %32 Disassembling Western Digital Essentials HD Anti-vibration rubber pieces, Disassembling Western Digital Essentials HD Anti-vibration rubber pieces: passo 6, imagem 2 %32
    • Remove the 4 rubber piece from the plastic frame at each corner.
  7. Disassembling Western Digital Essentials HD Anti-vibration rubber pieces: passo 7, imagem 1 %32
    • Remove the rubber piece from the SATA/USB bridge logic board.
Conclusão
Gaetan
Membro desde: 12/26/12
9.574 Reputação
Autoria de 18 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 1,551
