Ir para o conteúdo principal
Disassembling Toshiba T1960CS for HDD Removal
O que você precisa
  1. Disassembling Toshiba T1960CS for HDD Removal, HDD Removal: passo 1, imagem 1 %32
    • Pry up cover, remove screw.
  2. Disassembling Toshiba T1960CS for HDD Removal: passo 2, imagem 1 %32
    • Remove screws.
  3. Disassembling Toshiba T1960CS for HDD Removal: passo 3, imagem 1 %32
    • Gently pry out to unsnap top plastic housing.
  4. Disassembling Toshiba T1960CS for HDD Removal: passo 4, imagem 1 %32
    • Lift keyboard and flip over, but do not remove, it is still attached by ribbon cable.
    • Slide back connector tabs to release ribbon cable.
    • Remove 5 screws and lift out plate to access HDD and FDD.
  5. Disassembling Toshiba T1960CS for HDD Removal: passo 5, imagem 1 %32
    • To remove HDD loosen tape, lift out BIOS battery, remove screws and slide back HDD housing.
Conclusão
4 outras pessoas executaram este guia.
WayneG
Membro desde: 05/13/13
191 Reputação
Autoria de 1 guia
Um comentário
The plastic housing does not come off. It seems to be attached to the screen
James Blimthorpe - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 3,316
