Ir para o conteúdo principal
Disassembling Toshiba Satellite A65-S126 Upper and Lower Assemblies
Pré-requisito somente
Este guia destina-se apenas a ser usado como pré-requisito para outros guias. É incompleto por si só.
O que você precisa
  1. Disassembling Toshiba Satellite A65-S126 Upper and Lower Assemblies, Battery: passo 1, imagem 1 %32
    • Flip the laptop over so the bottom is facing up.
    • Slide each of the three tabs on the bottom half of the assembly into the unlocked position.
  2. Disassembling Toshiba Satellite A65-S126 Upper and Lower Assemblies: passo 2, imagem 1 %32
    • Gently lift the battery out of the computer.
  3. Disassembling Toshiba Satellite A65-S126 Upper and Lower Assemblies, Upper Assembly: passo 3, imagem 1 %32
    • Remove the single 3mm Phillips #00 screw that secures the wireless card cover.
  4. Disassembling Toshiba Satellite A65-S126 Upper and Lower Assemblies: passo 4, imagem 1 %32
    • Remove the WIFI module cover. It will pull right off.
  5. Disassembling Toshiba Satellite A65-S126 Upper and Lower Assemblies: passo 5, imagem 1 %32 Disassembling Toshiba Satellite A65-S126 Upper and Lower Assemblies: passo 5, imagem 2 %32
    • Unplug the white and black wires from the WiFi module.
  6. Disassembling Toshiba Satellite A65-S126 Upper and Lower Assemblies: passo 6, imagem 1 %32
    • Remove the twelve 8mm button head Phillips #00 B8 screws.
    • Remove the two 14 mm button head Phillips #00 B14 screws.
    • Remove the two 10 mm Phillips #00 battery compartment screws.
    • Remove the two 8 mm Phillips #00 screws.
  7. Disassembling Toshiba Satellite A65-S126 Upper and Lower Assemblies: passo 7, imagem 1 %32
    • Remove the seven 4mm flat Phillips #00 screws.
    • Remove the seven 20mm button head Phillips #00 screws.
  8. Disassembling Toshiba Satellite A65-S126 Upper and Lower Assemblies: passo 8, imagem 1 %32
    • Use the plastic opening tool to pry the two halves apart.
Conclusão
Geoff Wacker
Membro desde: 09/30/13
89.934 Reputação
Autoria de 89 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 232
