Introdução
Removing the back panel from the Toshiba AT1304T
If you can't get a hold of a Torx 6 Security Screwdriver, a small flathead can be used as a substitute
O que você precisa
Using a thumb-tack, push-pin, or similar pin, remove the four plastic stoppers located on the back panel.
Uma outra pessoa concluiu este guia.
