O que você precisa
Make sure your workplace is ESD secured
An ESD workmat and a ESD wristlet will get you far
Don't continue if your knowledge on ESD is lacking !
Purple screws dedicated to the keyboard, none of them should need removal
The bottom three screws has a rubber head upon them. Make sure you remove them carefully(some kind of adhesive on them).
Note that the screws will not jump out easily even though they are loose,
Remove the purple cable(battery). Might not be nessesary if you followed step 1 correctly
The blue indicates the M.2. SSD 42mm (2242). 256GB worked perfectly for me. Only exists if you have a version with separate cache.
Green box indicates the HDD
Red: RAM slot SO-DIMM DDR3 (only one) 8GB
7 outras pessoas executaram este guia.
2 comentários
Since older Lenovo are identical to open just look for an older model in case you have a brand new Lenovo and the hardware manual is not free availabe for download (very unusual).
Why would you edit and black-out the ASM, FRU and SN under the barcode of the battery sticker ?
Are you afraid someone is going to hack into your bank account or something with this info ?
There is nothing secret about these info that are written on the battery sticker.
These 3 codes are just there to identity the battery for process reasons and also in case it goes bad before warranty expires and you need to send the original battery back to the manufacturer.
Thanks for the guide.
