Ir para o conteúdo principal
Disassembling Speak And Spell Case
O que você precisa
  1. Disassembling Speak And Spell Case, Case: passo 1, imagem 1 %32 Disassembling Speak And Spell Case, Case: passo 1, imagem 2 %32
    • Flip the toy over, so that the keypad is facing away from you.
    • Remove two Phillips-head screws.
    • Insert a plastic spudger (or 4!) into the marked holes, and push down and towards the edge to release each catch.
    • It's possible to release each catch one-at-a-time, but easier if you have 4 tools and do them simultaneously.
    • This requires quite a bit of force; be careful.
  2. Disassembling Speak And Spell Case: passo 2, imagem 1 %32
    • Separate the two halves of the case to expose the inner PCB, speaker and battery holder.
Conclusão
bushing
Membro desde: 04/23/10
10.157 Reputação
Autoria de 13 guias
Um comentário
I got one of these. I've opened the case and the battery connections are silver and show no corrosion at all. I replaced the batteries, swapped out one of the Word Modules. I got a bit of static once, but now nothing. All the wire connection soldering looks fine. Any ideas?
stevehelium@gmail.com
Stephen Henderson - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 26
Duração total: 4,883
