Ir para o conteúdo principal
Disassembling Sony Vaio VGN-FW 590 Audio USB Board
O que você precisa
  1. Disassembling Sony Vaio VGN-FW 590 Audio USB Board, Audio USB Board: passo 1, imagem 1 %32
    • - Remove battery.
    • - Remove memory tray door (1 Screw).
    • - Remove hard drive door (1 Screw).
    • - Remove hard drive (3 Screws).
  2. Disassembling Sony Vaio VGN-FW 590 Audio USB Board: passo 2, imagem 1 %32
    • - Remove all screws from the bottom cover. There are three types of screws. Marked here with Red Circles, Red Squares and Orange Circles.
  3. Disassembling Sony Vaio VGN-FW 590 Audio USB Board: passo 3, imagem 1 %32
    • - Remove CD/DVD Drive by sliding it out.
    • - Remove three more screws, which were hiding under the DVD drive.
  4. Disassembling Sony Vaio VGN-FW 590 Audio USB Board: passo 4, imagem 1 %32
    • - Carefully remove the cover, by unpopping it with a slim flathead, slide it out away from the RJ-45, HDMI and VGA ports.
  5. Disassembling Sony Vaio VGN-FW 590 Audio USB Board: passo 5, imagem 1 %32
    • - The audio/usb interface card is now within reach. Just remove the two screws and carefully slide out the flat connector to remove the card.
  6. Disassembling Sony Vaio VGN-FW 590 Audio USB Board: passo 6, imagem 1 %32
    • - Fire up the air compressor and blow out dust from the fan and heatsinks.
  7. Disassembling Sony Vaio VGN-FW 590 Audio USB Board: passo 7, imagem 1 %32
    • - If you are replacing your RAM, simply unpop the four latches and slide out the memory sticks.
Conclusão
8 outras pessoas executaram este guia.
Artem Nikulkov
Membro desde: 10/22/10
313 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 11
Duração total: 21,133
