Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
This disassembly prerequisite is required to access most components in the phone, as the swivel assembly also secures the display section to its housing.
O que você precisa
Grip the lower portion of the back of the phone and slide downwards.
Unscrew the four Torx screws from the backplate.
The backplate may begin to separate from the keypad face. Do not try to remove it yet.
The screws are T5 Torx screws, 5.6mm.
