Ir para o conteúdo principal
Disassembling Sony Ericsson w600i Back Housing
O que você precisa
  1. Disassembling Sony Ericsson w600i Back Housing, Disassembling Sony Ericsson w600i Battery Cover: passo 1, imagem 1 %32
    • Grip the lower portion of the back of the phone and slide downwards.
  2. Disassembling Sony Ericsson w600i Back Housing, Battery: passo 2, imagem 1 %32
    • Lift battery at the rounded notch near the bottom of the phone.
  3. Disassembling Sony Ericsson w600i Back Housing, Back housing: passo 3, imagem 1 %32
    • Unscrew the four Torx screws from the backplate.
    • The backplate may begin to separate from the keypad face. Do not try to remove it yet.
    • The screws are T5 Torx screws, 5.6mm.
  4. Disassembling Sony Ericsson w600i Back Housing: passo 4, imagem 1 %32
    • Swivel the phone open.
  5. Disassembling Sony Ericsson w600i Back Housing: passo 5, imagem 1 %32
    • Using the Spudger, gently pry up the U-shaped grey cover below the keypad.
    • The cover is secured with adhesive tape. The gentler this is removed, the easier it will be to reassemble.
  6. Disassembling Sony Ericsson w600i Back Housing: passo 6, imagem 1 %32
    • Remove the two Torx screws from below the cover.
    • These are T5 Torx screws, 8.6mm.
  7. Disassembling Sony Ericsson w600i Back Housing: passo 7, imagem 1 %32
    • Gently work a spudger or a fingernail between the keypad face and the backplate.
    • The pieces are clipped together most tightly at the bottom loop section.
  8. Disassembling Sony Ericsson w600i Back Housing: passo 8, imagem 1 %32 Disassembling Sony Ericsson w600i Back Housing: passo 8, imagem 2 %32
    • Separate the keypad face from the backplate.
    • The keypad keys and the button component are both loose inside the phone, so take note of their orientation in case they become dislodged.
    • Take note of the braided cord's state. Upon reassembly it should be returned to the same orientation.
  9. Disassembling Sony Ericsson w600i Back Housing: passo 9, imagem 1 %32 Disassembling Sony Ericsson w600i Back Housing: passo 9, imagem 2 %32 Disassembling Sony Ericsson w600i Back Housing: passo 9, imagem 3 %32
    • Holding the backplate away from the swivel, remove the 4 small Phillips screws and both stamped struts from the swivel assembly.
    • Note that only the bottom strut has a tab.
    • The screws are Phillips, 2.9mm
  10. Disassembling Sony Ericsson w600i Back Housing: passo 10, imagem 1 %32
    • The back housing is now disassembled, and the swivel assembly is revealed.
Conclusão
Beau Blanchard
Membro desde: 09/30/12
20 Reputação
Autoria de 6 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 455
