Ir para o conteúdo principal
Disassembling Sony Ericsson QuickShare T630 Phone Enclosure
O que você precisa
  1. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure, Sony Ericsson QuickShare T630 Phone Enclosure: passo 1, imagem 1 %32
    • Begin the disassembly by placing your Sony Ericsson QuickShare T630 on a flat surface.
  2. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: passo 2, imagem 1 %32 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: passo 2, imagem 2 %32
    • Slide the protective panel on the backside of the phone downward and remove it entirely, revealing the battery underneath.
  3. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: passo 3, imagem 1 %32
    • Slide the battery upward to remove.
  4. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: passo 4, imagem 1 %32 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: passo 4, imagem 2 %32
    • Remove the rubber plug located near the camera by gently prying upward with your fingers.
    • Gently lift the camera shield after removal of the rubber plug.
  5. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: passo 5, imagem 1 %32 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: passo 5, imagem 2 %32
    • Pry the remaining panel to loosen its contact to the phone using a spudger.
    • Slide the panel upward to remove it completely.
    • These steps will require a slight appliance of force.
  6. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: passo 6, imagem 1 %32
    • Slide the aerial upward to remove it.
  7. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: passo 7, imagem 1 %32 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: passo 7, imagem 2 %32
    • Remove the four screws located at each corner of the device.
  8. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: passo 8, imagem 1 %32 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: passo 8, imagem 2 %32
    • Gently lift and remove the front panel of the phone after removing the screws.
  9. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: passo 9, imagem 1 %32 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: passo 9, imagem 2 %32 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: passo 9, imagem 3 %32
    • This step is NOT required for joystick maintenance or keypad maintenance and replacement! Continue on to step 10 if you are attempting to achieve either of these goals.
    • Slowly lift the screen to reveal the green circuit ribbon connecting the screen to the phone.
    • Gently pull the ribbon from the circuit.
    • Remove the now disconnected screen.
  10. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: passo 10, imagem 1 %32 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: passo 10, imagem 2 %32 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: passo 10, imagem 3 %32
    • Remove the keyboard by slowly pulling it away from the circuit board.
    • There are no direct connections between the keyboard and phone.
    • These are all of the parts covered in this disassembly that make up the Sony Ericsson QuickShare T630.
Conclusão
Christine Becker
Membro desde: 10/28/13
101 Reputação
Autoria de 1 guia
Equipe
University of Maine, Team 1-13, Diaz Fall 2013 Membro de University of Maine, Team 1-13, Diaz Fall 2013
UMAINE-DIAZ-F13S1G13
Membros da 3
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 3,514
