Ir para o conteúdo principal
Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover
O que você precisa
  1. Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover, Battery: passo 1, imagem 1 %32 Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover, Battery: passo 1, imagem 2 %32
    • Locate the battery door at the bottom of the camera.
    • Press down on the door and slide it back. The door will pop open.
  2. Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: passo 2, imagem 1 %32
    • Remove the battery from the door that you opened in the previous step.
  3. Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: passo 3, imagem 1 %32 Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: passo 3, imagem 2 %32 Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: passo 3, imagem 3 %32
    • There are two screws on the left and right sides of the camera, and two screws on the bottom.
    • Use a PH00 screwdriver and remove the six 2.9mm screws.
  4. Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: passo 4, imagem 1 %32 Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: passo 4, imagem 2 %32
    • Use hands to gently pry the front casing away from the camera.
Conclusão
Uma outra pessoa concluiu este guia.
iDeleted
Membro desde: 07/07/10
2.101 Reputação
Autoria de 39 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 11
Duração total: 2,577
