Ir para o conteúdo principal
Disassembling Sony Clie PEG-SL10
O que você precisa
  1. Disassembling Sony Clie PEG-SL10, Disassembling Sony Clie PEG-SL10: passo 1, imagem 1 %32
    • Start by holding your Sony Clie PEG-SL10 face-up in your hand.
  2. Disassembling Sony Clie PEG-SL10: passo 2, imagem 1 %32
    • Turn over your Sony Clie and unlock the cover slide lock.
  3. Disassembling Sony Clie PEG-SL10: passo 3, imagem 1 %32
    • After unlocking the cover slide lock, remove the cover and set aside.
  4. Disassembling Sony Clie PEG-SL10: passo 4, imagem 1 %32
    • Turn your Sony Clie face-up.
    • Using a Phillips #0 screwdriver, remove the six case screws on the sides and bottom of the device.
  5. Disassembling Sony Clie PEG-SL10: passo 5, imagem 1 %32
    • Remove the front case by gently lifting away from the device.
  6. Disassembling Sony Clie PEG-SL10: passo 6, imagem 1 %32
    • Turn the Sony Clie face down and open the back case by prying open the left side of the device.
    • It will open like a book connected by hinges on the right side.
  7. Disassembling Sony Clie PEG-SL10: passo 7, imagem 1 %32
    • Gently pry off the right side off the back panel and set it aside, leaving room for the scroll wheel at the upper right corner.
  8. Disassembling Sony Clie PEG-SL10: passo 8, imagem 1 %32
    • Using a Phillips #0 screwdriver, remove the two screws holding the scroll wheel in place.
  9. Disassembling Sony Clie PEG-SL10: passo 9, imagem 1 %32
    • Pull out both sides of the clip to remove the scroll wheel power cable from the device.
  10. Disassembling Sony Clie PEG-SL10: passo 10, imagem 1 %32
    • Using a Phillips #0 screwdriver, unscrew the two screws towards the bottom sides of the Sony Clie to remove the battery harness.
  11. Disassembling Sony Clie PEG-SL10: passo 11, imagem 1 %32
    • Pull the power cable from the socket located above the upper right side of the battery harness.
  12. Disassembling Sony Clie PEG-SL10: passo 12, imagem 1 %32
    • Gently pull out the clips to remove the bottom power cables from the motherboard after removing the battery harness.
  13. Disassembling Sony Clie PEG-SL10: passo 13, imagem 1 %32
    • Rotate the motherboard 180 degrees so that it is upside down facing toward you to expose the power cables on the other side.
  14. Disassembling Sony Clie PEG-SL10: passo 14, imagem 1 %32
    • Gently pull out the clips to remove the top power cables from the motherboard.
Conclusão
Documentos anexados
Steve
Membro desde: 10/18/11
9 Reputação
Autoria de 1 guia
Equipe
James Madison, Team 1-4, Allen Fall 2011 Membro de James Madison, Team 1-4, Allen Fall 2011
JMU-ALLEN-F11S1G4
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 1,748
