Peças
Não são necessárias peças.
  1. Unscrew the 1.9mm screw located at the top of the device with a Phillips #00 screwdriver.
    • Unscrew the 1.9mm screw located at the top of the device with a Phillips #00 screwdriver.
    • It may be helpful to set up a piece of paper to keep track of where removed screws came from.
  2. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  3. Unscrew the 2.5mm screw located on the left side of the device with a Phillips #00 screwdriver.
    • Unscrew the 2.5mm screw located on the left side of the device with a Phillips #00 screwdriver.
  4. Unscrew the five 2.5mm screws on the back panel with a Phillips #00 screwdriver. Remove the back panel by lifting it away with your hands.
    • Unscrew the five 2.5mm screws on the back panel with a Phillips #00 screwdriver.
    • Remove the back panel by lifting it away with your hands.
Conclusão
Daniel Soski
20 reputação
6 Guides authored
Equipe
Cal Poly, Team 14-11, Maness Spring 2013 Membro de Cal Poly, Team 14-11, Maness Spring 2013
CPSU-MANESS-S13S14G11
5 Membros
8 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Todo: 327
