Introdução
You will take apart the camera case to access the circuit board after removing the battery. Be ready to handle small parts and screws.
O que você precisa
Open the bottom tab with your finger or a plastic opening tool.
Pull the tab out, not up, to remove it completely.
Remove the two screws from the device.
Use your fingers to remove the plastic plate.
3 outras pessoas executaram este guia.
