Ir para o conteúdo principal
Disassembling Sony Action Cam HDR-AS15 Circuit Board
O que você precisa
  1. Disassembling Sony Action Cam HDR-AS15 Circuit Board, Battery: passo 1, imagem 1 %32
    • To access the battery, gently pry open the rear cover of the action cam.
  2. Disassembling Sony Action Cam HDR-AS15 Circuit Board: passo 2, imagem 1 %32 Disassembling Sony Action Cam HDR-AS15 Circuit Board: passo 2, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using a pair of tweezers, firmly grip the protrusion where the PULL signifies and remove the tray and battery.
  3. Disassembling Sony Action Cam HDR-AS15 Circuit Board, Disassembling Sony Action Cam HDR-AS15 Circuit Board: passo 3, imagem 1 %32 Disassembling Sony Action Cam HDR-AS15 Circuit Board, Disassembling Sony Action Cam HDR-AS15 Circuit Board: passo 3, imagem 2 %32 Disassembling Sony Action Cam HDR-AS15 Circuit Board, Disassembling Sony Action Cam HDR-AS15 Circuit Board: passo 3, imagem 3 %32
    • Open the bottom tab with your finger or a plastic opening tool.
    • Pull the tab out, not up, to remove it completely.
    • Remove the two screws from the device.
    • Use your fingers to remove the plastic plate.
  4. Disassembling Sony Action Cam HDR-AS15 Circuit Board: passo 4, imagem 1 %32
    • Separate the outer casing from the electronics by pushing on one of the ports toward the back end of the case. The electronics should slide right out.
  5. Disassembling Sony Action Cam HDR-AS15 Circuit Board: passo 5, imagem 1 %32 Disassembling Sony Action Cam HDR-AS15 Circuit Board: passo 5, imagem 2 %32
    • Remove the two 6.4 mm screws on the LCD side of the device using a Phillips #00 screwdriver.
    • Flip the LCD display downward to reveal the circuit board.
Conclusão
3 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 1-2, Sullivan Winter 2015 Membro de USF Tampa, Team 1-2, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G2
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Duração total: 1,655
