Ir para o conteúdo principal
Snapfōn ezONE LCD Screen Replacement
O que você precisa
  1. Snapfōn ezONE LCD Screen Replacement, Remove the battery cover: passo 1, imagem 1 %32
    • Turn off the phone to prevent data loss.
    • Press and slide the battery out to remove it.
    • Picture rights belong to Snapfon®. Picture is used for educational purposes only. No copyright infringement intended.
  2. Snapfōn ezONE LCD Screen Replacement, Remove the battery: passo 2, imagem 1 %32
    • Pry the battery out with your thumb or the iFixit opening tool.
    • Make sure to properly dispose of the old battery at a recycling center.
  3. Snapfōn ezONE LCD Screen Replacement, Removing the plastic inserts: passo 3, imagem 1 %32 Snapfōn ezONE LCD Screen Replacement, Removing the plastic inserts: passo 3, imagem 2 %32
    • Remove the four rubber inserts from the screw holes using a pair of tweezers.
  4. Snapfōn ezONE LCD Screen Replacement, Remove the shield screws: passo 4, imagem 1 %32 Snapfōn ezONE LCD Screen Replacement, Remove the shield screws: passo 4, imagem 2 %32 Snapfōn ezONE LCD Screen Replacement, Remove the shield screws: passo 4, imagem 3 %32
    • Remove the four 3.1mm screws in the corners with a Phillips #00 screwdriver.
  5. Snapfōn ezONE LCD Screen Replacement, Separate the case: passo 5, imagem 1 %32 Snapfōn ezONE LCD Screen Replacement, Separate the case: passo 5, imagem 2 %32 Snapfōn ezONE LCD Screen Replacement, Separate the case: passo 5, imagem 3 %32
    • Separate the front case from the back case.
    • Remove the metal bumper from the front case’s perimeter.
  6. Snapfōn ezONE LCD Screen Replacement, Remove the volume slider: passo 6, imagem 1 %32
    • Pry the volume slider button out with tweezers.
    • The volume slider button may fall out during the separation of the front and back cases. This is OK.
  7. Snapfōn ezONE LCD Screen Replacement, Remove the motherboard: passo 7, imagem 1 %32 Snapfōn ezONE LCD Screen Replacement, Remove the motherboard: passo 7, imagem 2 %32 Snapfōn ezONE LCD Screen Replacement, Remove the motherboard: passo 7, imagem 3 %32
    • Separate the circuit board from the inside of the back case by prying between them with the opening tool.
    • The last picture is a view of the back of the circuit board.
  8. Snapfōn ezONE LCD Screen Replacement, Pry the screen back: passo 8, imagem 1 %32 Snapfōn ezONE LCD Screen Replacement, Pry the screen back: passo 8, imagem 2 %32 Snapfōn ezONE LCD Screen Replacement, Pry the screen back: passo 8, imagem 3 %32
    • Pry the LCD screen off of the circuit board using the opening tool. The screen is connected to the motherboard with light adhesive, which is easy to remove.
    • The LCD screen will still be connected to the circuit board by a ribbon cable.
  9. Snapfōn ezONE LCD Screen Replacement, Disconnect the display: passo 9, imagem 1 %32
    • Use a soldering iron to melt away the connection between the ribbon cable and circuit board.
    • Be careful! High temperatures from the soldering iron may result in injury.
    • Only make contact with the solder connection so that none of the phone’s components are damaged by the heat.
  10. Snapfōn ezONE LCD Screen Replacement, Remove the display: passo 10, imagem 1 %32 Snapfōn ezONE LCD Screen Replacement, Remove the display: passo 10, imagem 2 %32
    • Once you heat the solder connection, lightly tug the ribbon cable free. The LCD screen will be completely removed from the device.
Conclusão
To reassemble your device with a new LCD screen, follow these instructions in reverse order.
Note: you will need to use the soldering iron again to attach the new LCD screen ribbon to the circuit board.
Uma outra pessoa concluiu este guia.
John Bender
Membro desde: 03/26/14
818 Reputação
Autoria de 8 guias
Equipe
Clemson, Team 6-5, Benson Spring 2014 Membro de Clemson, Team 6-5, Benson Spring 2014
CLEM-BENSON-S14S6G5
Membros da 3
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 427
