Ir para o conteúdo principal
Disassembling Sirius Stiletto 100 Front Cover
O que você precisa
  1. Disassembling Sirius Stiletto 100 Front Cover, Front Cover: passo 1, imagem 1 %32 Disassembling Sirius Stiletto 100 Front Cover, Front Cover: passo 1, imagem 2 %32
    • Remove the battery (which also functions as the back cover) from the device. This step is not explicitly shown, but a picture without the battery cover shows the device post-battery removal.
  2. Disassembling Sirius Stiletto 100 Front Cover: passo 2, imagem 1 %32 Disassembling Sirius Stiletto 100 Front Cover: passo 2, imagem 2 %32
    • Use a Philip's head screw driver to remove the screws from the case.
    • Place the screws in a small container to avoid losing them.
  3. Disassembling Sirius Stiletto 100 Front Cover: passo 3, imagem 1 %32 Disassembling Sirius Stiletto 100 Front Cover: passo 3, imagem 2 %32 Disassembling Sirius Stiletto 100 Front Cover: passo 3, imagem 3 %32
    • Remove the front cover.
    • First, insert a small pry bar where the black front cover and white back cover meet.
    • Begin prying the black plastic up, slowing moving around to the bottom and other side.
    • At an angle, carefully pull up on the front cover separate the two pieces.
    • Excellent! Now you have removed the front cover!
Conclusão
Trey
Membro desde: 03/09/12
80 Reputação
Autoria de 2 guias
Equipe
Clemson, Team 2-1, Benson Spring 2012 Membro de Clemson, Team 2-1, Benson Spring 2012
CLEM-BENSON-S12S2G1
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 13
Duração total: 1,573
