Ir para o conteúdo principal
Disassembling Sirius Stiletto 100 Circuit Board
O que você precisa
  1. Disassembling Sirius Stiletto 100 Circuit Board, Front Cover: passo 1, imagem 1 %32 Disassembling Sirius Stiletto 100 Circuit Board, Front Cover: passo 1, imagem 2 %32
    • Remove the battery (which also functions as the back cover) from the device. This step is not explicitly shown, but a picture without the battery cover shows the device post-battery removal.
  2. Disassembling Sirius Stiletto 100 Circuit Board: passo 2, imagem 1 %32 Disassembling Sirius Stiletto 100 Circuit Board: passo 2, imagem 2 %32
    • Use a Philip's head screw driver to remove the screws from the case.
    • Place the screws in a small container to avoid losing them.
  3. Disassembling Sirius Stiletto 100 Circuit Board: passo 3, imagem 1 %32 Disassembling Sirius Stiletto 100 Circuit Board: passo 3, imagem 2 %32 Disassembling Sirius Stiletto 100 Circuit Board: passo 3, imagem 3 %32
    • Remove the front cover.
    • First, insert a small pry bar where the black front cover and white back cover meet.
    • Begin prying the black plastic up, slowing moving around to the bottom and other side.
    • At an angle, carefully pull up on the front cover separate the two pieces.
    • Excellent! Now you have removed the front cover!
  4. Disassembling Sirius Stiletto 100 Circuit Board, Circuit Board: passo 4, imagem 1 %32
    • While looking down at the device, place your index finger at the top of the circuit board and your thumb on the device screen.
  5. Disassembling Sirius Stiletto 100 Circuit Board: passo 5, imagem 1 %32 Disassembling Sirius Stiletto 100 Circuit Board: passo 5, imagem 2 %32
    • Using your fingers, gently pull the top of the circuit board up toward you while also sliding the bottom of the circuit board away from the bottom of the Sirius Stiletto 100 back cover.
  6. Disassembling Sirius Stiletto 100 Circuit Board: passo 6, imagem 1 %32
    • Congratulations! You have successfully removed the internal circuit board from the Sirius Stiletto 100 back cover.
Conclusão
Staten
Membro desde: 03/09/12
69 Reputação
Autoria de 1 guia
Equipe
Clemson, Team 2-1, Benson Spring 2012 Membro de Clemson, Team 2-1, Benson Spring 2012
CLEM-BENSON-S12S2G1
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 1,916
