Ir para o conteúdo principal
Disassembling Siemens A56 Motherboard from Keypad Interface
O que você precisa
  1. Disassembling Siemens A56 Motherboard from Keypad Interface, Battery: passo 1, imagem 1 %32
    • Press down on the grooved area firmly in the direction of arrow #1.
    • While maintaining the downwards pressure, push the back cover in the direction of arrow #2 until the back cover slides off.
    • Photos taken from: http://theinformr.com/uploads/manuals/si...
  2. Disassembling Siemens A56 Motherboard from Keypad Interface: passo 2, imagem 1 %32
    • Turn off the phone before removing the battery to avoid damage.
    • Press the latch on the battery in the direction of arrow #3.
    • Lift battery at the cutout on the side of the phone, then tilt upwards and remove.
    • It may be necessary to use the tip of a fingernail or a plastic lifting tool to remove the battery.
  3. Disassembling Siemens A56 Motherboard from Keypad Interface, Front Plate: passo 3, imagem 1 %32 Disassembling Siemens A56 Motherboard from Keypad Interface, Front Plate: passo 3, imagem 2 %32 Disassembling Siemens A56 Motherboard from Keypad Interface, Front Plate: passo 3, imagem 3 %32
    • Firmly grasp the white casing of the phone with one hand and the blue cover with the other hand as seen in the first picture.
    • Pull up on the two plastic clips at the top of the phone.
    • While the clips are pulled up, pull the blue cover away from the white casing to remove it.
  4. Disassembling Siemens A56 Motherboard from Keypad Interface, Back Plastic Cover: passo 4, imagem 1 %32 Disassembling Siemens A56 Motherboard from Keypad Interface, Back Plastic Cover: passo 4, imagem 2 %32 Disassembling Siemens A56 Motherboard from Keypad Interface, Back Plastic Cover: passo 4, imagem 3 %32
    • Along the side of the metal frame of the phone, locate the six screws.
    • Using a T5 screwdriver bit, unscrew the six 1/4 inch screws and store them in a safe place.
    • The screws are very small and can strip easily, so proper care is required when removing and storing the screws.
  5. Disassembling Siemens A56 Motherboard from Keypad Interface: passo 5, imagem 1 %32 Disassembling Siemens A56 Motherboard from Keypad Interface: passo 5, imagem 2 %32 Disassembling Siemens A56 Motherboard from Keypad Interface: passo 5, imagem 3 %32
    • To remove the back plastic cover, grasp the device with both hands as seen in the first picture.
    • Gently remove the motherboard from the back plastic cover.
    • The motherboard is fragile, so proper care is necessary when handling and storing in order to prevent damage.
  6. Disassembling Siemens A56 Motherboard from Keypad Interface, Motherboard Metal Frame: passo 6, imagem 1 %32 Disassembling Siemens A56 Motherboard from Keypad Interface, Motherboard Metal Frame: passo 6, imagem 2 %32 Disassembling Siemens A56 Motherboard from Keypad Interface, Motherboard Metal Frame: passo 6, imagem 3 %32
    • Turn over the keypad interface and using the blue plastic opening tool, gently pry the bottom of the metal frame.
    • Once loosened, the metal frame should be able to be lifted from the motherboard.
  7. Disassembling Siemens A56 Motherboard from Keypad Interface, Motherboard from Keypad Interface: passo 7, imagem 1 %32 Disassembling Siemens A56 Motherboard from Keypad Interface, Motherboard from Keypad Interface: passo 7, imagem 2 %32 Disassembling Siemens A56 Motherboard from Keypad Interface, Motherboard from Keypad Interface: passo 7, imagem 3 %32
    • Insert the fine-tipped spudger in between the motherboard and the keypad interface.
    • Gently work the spudger across the length of the motherboard.
    • An adhesive exists between the motherboard and the keypad interface.
    • Once loosened, the motherboard should easily separate from the keypad interface.
Conclusão
Joseph Casey
Membro desde: 03/26/14
409 Reputação
Autoria de 4 guias
Equipe
Clemson, Team 6-6, Benson Spring 2014 Membro de Clemson, Team 6-6, Benson Spring 2014
CLEM-BENSON-S14S6G6
Membros da 4
Autoria de 18 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 14
Duração total: 221
