O que você precisa
Firmly grasp the white casing of the phone with one hand and the blue cover with the other hand as seen in the first picture.
Pull up on the two plastic clips at the top of the phone.
While the clips are pulled up, pull the blue cover away from the white casing to remove it.
Along the side of the metal frame of the phone, locate the six screws.
Using a T5 screwdriver bit, unscrew the six 1/4 inch screws and store them in a safe place.
Turn over the keypad interface and using the blue plastic opening tool, gently pry the bottom of the metal frame.
Once loosened, the metal frame should be able to be lifted from the motherboard.
