Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
This is how you would remove the outer panels of the Sanyo VPC-T850. This step is required for any repairs or a tear down.
O que você precisa
Turn the camera off by pressing the small, square button embedded in the top rim of the camera.
Slide out and open the hatch located on the bottom-right side of the camera.
In the revealed compartment, move the small notch and push in on the battery to remove it.
Using the Phillips #00 Screwdriver, remove the 8 screws located around the sides and bottom of the camera.
Using the spudger, slowly pry the rear panel away from the left side.
