Ir para o conteúdo principal
Disassembling Sanyo Katana Eclipse X's Back Panel
O que você precisa
  1. Disassembling Sanyo Katana Eclipse X's Back Panel, Back Panel: passo 1, imagem 1 %32 Disassembling Sanyo Katana Eclipse X's Back Panel, Back Panel: passo 1, imagem 2 %32
    • Press the battery release button located on the back of the phone.
    • With the button depressed, pull down on the battery protector to remove it from the phone.
    • The phone's battery will now be exposed.
  2. Disassembling Sanyo Katana Eclipse X's Back Panel: passo 2, imagem 1 %32
    • Slide a thin object under the white tab located on the bottom of the battery and carefully lift away from the phone.
    • A small, flat-tip screwdriver or credit card may be helpful for this step.
    • The battery should now be free of the phone.
Conclusão
Thomas Scaggs
Membro desde: 10/15/12
209 Reputação
Autoria de 2 guias
Equipe
University of Maine, Team 1-3, Diaz Fall 2012 Membro de University of Maine, Team 1-3, Diaz Fall 2012
UMAINE-DIAZ-F12S1G3
Membros da 5
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 289
