Ir para o conteúdo principal
Disassembling Samsung TFT Color YP-T7J USB Connector Dock
O que você precisa
  1. Disassembling Samsung TFT Color YP-T7J USB Connector Dock, The Back Cover: passo 1, imagem 1 %32 Disassembling Samsung TFT Color YP-T7J USB Connector Dock, The Back Cover: passo 1, imagem 2 %32
    • Remove the 2 screws on the back cover using a Phillips head #0 screwdriver.
  2. Disassembling Samsung TFT Color YP-T7J USB Connector Dock: passo 2, imagem 1 %32 Disassembling Samsung TFT Color YP-T7J USB Connector Dock: passo 2, imagem 2 %32
    • Remove the screw on each side of the device using a Phillips head screwdriver.
  3. Disassembling Samsung TFT Color YP-T7J USB Connector Dock: passo 3, imagem 1 %32 Disassembling Samsung TFT Color YP-T7J USB Connector Dock: passo 3, imagem 2 %32 Disassembling Samsung TFT Color YP-T7J USB Connector Dock: passo 3, imagem 3 %32
    • Using the plastic opening kit, place the prying end of the kit into the opening created by removing the screws.
    • Gently pry open the back cover. Insert the plastic opening tool in between the cover joints.
  4. Disassembling Samsung TFT Color YP-T7J USB Connector Dock, The Battery: passo 4, imagem 1 %32 Disassembling Samsung TFT Color YP-T7J USB Connector Dock, The Battery: passo 4, imagem 2 %32
    • Once the back cover has been removed the battery will be visible.
    • Pry the battery from the device.
    • NOTE: The battery should still be connected to the device
  5. Disassembling Samsung TFT Color YP-T7J USB Connector Dock: passo 5, imagem 1 %32 Disassembling Samsung TFT Color YP-T7J USB Connector Dock: passo 5, imagem 2 %32
    • Unplug the battery connecting cables.
    • NOTE: The battery now should be free from all connections to the device.
  6. Disassembling Samsung TFT Color YP-T7J USB Connector Dock, Disassembling Samsung TFT Color YP-T7J USB Connector Dock: passo 6, imagem 1 %32 Disassembling Samsung TFT Color YP-T7J USB Connector Dock, Disassembling Samsung TFT Color YP-T7J USB Connector Dock: passo 6, imagem 2 %32 Disassembling Samsung TFT Color YP-T7J USB Connector Dock, Disassembling Samsung TFT Color YP-T7J USB Connector Dock: passo 6, imagem 3 %32
    • Once the battery has been removed you can see the motherboard.
    • Unscrew 4 screws on the metal docket using a Phillips head screw driver.
    • The USB connector can now be taken off of the device.
Conclusão
Dylan Peters
Membro desde: 10/18/13
409 Reputação
Autoria de 4 guias
Equipe
Clemson, Team 14-8, Benson Fall 2013 Membro de Clemson, Team 14-8, Benson Fall 2013
CLEM-BENSON-F13S14G8
3 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 7
Ao todo: 636
