Ir para o conteúdo principal
Disassembling Samsung TFT Color YP-T7J Removing the Front Cover
O que você precisa
  1. Disassembling Samsung TFT Color YP-T7J Removing the Front Cover, The Back Cover: passo 1, imagem 1 %32 Disassembling Samsung TFT Color YP-T7J Removing the Front Cover, The Back Cover: passo 1, imagem 2 %32
    • Remove the 2 screws on the back cover using a Phillips head #0 screwdriver.
  2. Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: passo 2, imagem 1 %32 Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: passo 2, imagem 2 %32
    • Remove the screw on each side of the device using a Phillips head screwdriver.
  3. Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: passo 3, imagem 1 %32 Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: passo 3, imagem 2 %32 Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: passo 3, imagem 3 %32
    • Using the plastic opening kit, place the prying end of the kit into the opening created by removing the screws.
    • Gently pry open the back cover. Insert the plastic opening tool in between the cover joints.
  4. Disassembling Samsung TFT Color YP-T7J Removing the Front Cover, The Front Cover: passo 4, imagem 1 %32 Disassembling Samsung TFT Color YP-T7J Removing the Front Cover, The Front Cover: passo 4, imagem 2 %32
    • Using the philips screwdriver, remove the two screws on the mother board.
  5. Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: passo 5, imagem 1 %32 Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: passo 5, imagem 2 %32 Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: passo 5, imagem 3 %32
    • Place the pry tool in-between the front cover and mother board.
    • Gently separate the front cover.
  6. Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: passo 6, imagem 1 %32
    • After opening the front cover you will see and electric ribbon connecting the buttons to the mother board.
  7. Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: passo 7, imagem 1 %32 Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: passo 7, imagem 2 %32
    • CAUTION: Do not rip the electric ribbon from the mother board.
    • Carefully flip up the plastic lip that holds the electric ribbon to the board.
Conclusão
Uma outra pessoa concluiu este guia.
Jason Farr
Membro desde: 10/21/13
353 Reputação
Autoria de 3 guias
Equipe
Clemson, Team 14-8, Benson Fall 2013 Membro de Clemson, Team 14-8, Benson Fall 2013
CLEM-BENSON-F13S14G8
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 12
Duração total: 254
