Ir para o conteúdo principal
Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Disassembling Samsung Laptop Ultrabook NP530U3B
O que você precisa
  1. Disassembling Samsung Laptop Ultrabook NP530U3B, Ultrabook NP530U3B: passo 1, imagem 1 %32
    • Remove the 8 small screws.
  2. Disassembling Samsung Laptop Ultrabook NP530U3B: passo 2, imagem 1 %32 Disassembling Samsung Laptop Ultrabook NP530U3B: passo 2, imagem 2 %32
    • Remove the other 6 screws.
    • Hard disk.
    • RAM slots.
  3. Disassembling Samsung Laptop Ultrabook NP530U3B: passo 3, imagem 1 %32
    • Hard disk - Hitachi 500 GB
  4. Disassembling Samsung Laptop Ultrabook NP530U3B: passo 4, imagem 1 %32
    • The hard disk should have been taken out before this step.
    • Carefully detach the bottom cover.
  5. Disassembling Samsung Laptop Ultrabook NP530U3B: passo 5, imagem 1 %32
    • Bottom cover removed
  6. Disassembling Samsung Laptop Ultrabook NP530U3B: passo 6, imagem 1 %32
    • Remove the 4 screws to detach the battery.
    • Remove al the sticky tape.
    • Carefully disconnect the small power connector by using a tool to push the connector out through the small gap mid-connector. It won't come out all the way, because the battery pack is in its way.
  7. Disassembling Samsung Laptop Ultrabook NP530U3B: passo 7, imagem 1 %32 Disassembling Samsung Laptop Ultrabook NP530U3B: passo 7, imagem 2 %32
    • Samsung 7.4V 45Wh battery.
  8. Disassembling Samsung Laptop Ultrabook NP530U3B: passo 8, imagem 1 %32
    • Battery removed.
  9. Disassembling Samsung Laptop Ultrabook NP530U3B: passo 9, imagem 1 %32
    • Remove Fan with Processor heat sink.
    • ( 2 screws)
  10. Disassembling Samsung Laptop Ultrabook NP530U3B: passo 10, imagem 1 %32
    • (3 screws)
  11. Disassembling Samsung Laptop Ultrabook NP530U3B: passo 11, imagem 1 %32
    • Disconnect antenna cables from WiFi card.
    • Remove the screw.
    • Be sure to match the colors when reattaching the cables.
  12. Disassembling Samsung Laptop Ultrabook NP530U3B: passo 12, imagem 1 %32
    • Remove this screw.
    • Uplift the latch to loose the cable.
  13. Disassembling Samsung Laptop Ultrabook NP530U3B: passo 13, imagem 1 %32
  14. Disassembling Samsung Laptop Ultrabook NP530U3B: passo 14, imagem 1 %32
  15. Disassembling Samsung Laptop Ultrabook NP530U3B: passo 15, imagem 1 %32
    • To remove Motherboard, carefully disconnect the cables.
  16. Disassembling Samsung Laptop Ultrabook NP530U3B: passo 16, imagem 1 %32 Disassembling Samsung Laptop Ultrabook NP530U3B: passo 16, imagem 2 %32
    • Motherboard - front and rear
  17. Disassembling Samsung Laptop Ultrabook NP530U3B: passo 17, imagem 1 %32
    • Processor fan.
Conclusão
34 outras pessoas executaram este guia.
30 comentários
Hello,
Do you know where can i reset the Bios CMOS in that motherboard?
I think there are people who wants to know becose system upgrade is leading to bios ACPI Error.
Thanks for your help
Luis Orland - Responder
No, I do not know where is a reset pin of BIOS.
Try to disconnect NVRAM battery.
Wait 15 minutes and reconnect again.
Jose Gustavo Abreu Murta - Responder
To reset BIOS this NP530U3, only disconnect all power supply (MAIN battery, CMOS battery and power source). And hold press POWER button for 1 min.
warmdk - Responder
I try it but don't work, do you know another way to do this
manhique -
Hello,
I have seen many screens with model number LTN140AT21-XXX for this laptop. My laptop NP530u4b has a screen LTN140AT21-802. I would like to know if I can use a LTN140AT21-002 screen, or if only is good a screen with number LTN140AT21-8.
thanks for your help.
alex - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 14
Últimos 30 dias: 79
Duração total: 52,929
