Ir para o conteúdo principal
Disassembling Samsung Gravity SGH-T459 Keypad
O que você precisa
  1. Disassembling Samsung Gravity SGH-T459 Keypad, Disassembling Samsung Gravity SGH-T459  Back Cover: passo 1, imagem 1 %32
    • Press and hold the End key to power down the cell phone.
    • Gently remove the back cover with your fingers by sliding it in the direction of the arrows.
  2. Disassembling Samsung Gravity SGH-T459 Keypad, Disassembling Samsung Gravity SGH-T459  Battery: passo 2, imagem 1 %32
    • Gently lift up and remove battery with your fingers in the direction of the arrows.
  3. Disassembling Samsung Gravity SGH-T459 Keypad, Rear Case: passo 3, imagem 1 %32 Disassembling Samsung Gravity SGH-T459 Keypad, Rear Case: passo 3, imagem 2 %32 Disassembling Samsung Gravity SGH-T459 Keypad, Rear Case: passo 3, imagem 3 %32
    • Hold the cell phone steady with one hand. With the other hand, use a Phillips screwdriver to remove all 6 screws around the edges of the rear case.
    • Slide the phone open.
    • Use a plastic prying tool to pry open the edge of the green trim near the space bar of the keypad. You should hear the rear case unsnap.
    • Gently lift and remove the rear case from the cell phone.
  4. Disassembling Samsung Gravity SGH-T459 Keypad, Keypad: passo 4, imagem 1 %32 Disassembling Samsung Gravity SGH-T459 Keypad, Keypad: passo 4, imagem 2 %32 Disassembling Samsung Gravity SGH-T459 Keypad, Keypad: passo 4, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Gently remove the two button contacts with your fingers.
    • Use a plastic prying tool to pry the keypad away from the circuit board.
    • Use tweezers to gently remove the keypad.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 794
