Ir para o conteúdo principal
Disassembling Samsung Gravity SGH-T459 1.3 megapixel camera
O que você precisa
  1. Disassembling Samsung Gravity SGH-T459 1.3 megapixel camera, Disassembling Samsung Gravity SGH-T459  Back Cover: passo 1, imagem 1 %32
    • Press and hold the End key to power down the cell phone.
    • Gently remove the back cover with your fingers by sliding it in the direction of the arrows.
  2. Disassembling Samsung Gravity SGH-T459 1.3 megapixel camera, Disassembling Samsung Gravity SGH-T459  Battery: passo 2, imagem 1 %32
    • Gently lift up and remove battery with your fingers in the direction of the arrows.
  3. Disassembling Samsung Gravity SGH-T459 1.3 megapixel camera, Rear Case: passo 3, imagem 1 %32 Disassembling Samsung Gravity SGH-T459 1.3 megapixel camera, Rear Case: passo 3, imagem 2 %32 Disassembling Samsung Gravity SGH-T459 1.3 megapixel camera, Rear Case: passo 3, imagem 3 %32
    • Hold the cell phone steady with one hand. With the other hand, use a Phillips screwdriver to remove all 6 screws around the edges of the rear case.
    • Slide the phone open.
    • Use a plastic prying tool to pry open the edge of the green trim near the space bar of the keypad. You should hear the rear case unsnap.
    • Gently lift and remove the rear case from the cell phone.
  4. Disassembling Samsung Gravity SGH-T459 1.3 megapixel camera, 1.3 megapixel camera: passo 4, imagem 1 %32 Disassembling Samsung Gravity SGH-T459 1.3 megapixel camera, 1.3 megapixel camera: passo 4, imagem 2 %32
    • Gently lift and remove the 1.3 megapixel camera with your fingers.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 6
Duração total: 696
