Ir para o conteúdo principal
Disassembling Samsung Galaxy S Blaze Whole Device
O que você precisa
  1. Disassembling Samsung Galaxy S Blaze Whole Device, Disassembling Samsung Galaxy S Blaze Whole Device: passo 1, imagem 1 %32
    • Remove the back plate.
  2. Disassembling Samsung Galaxy S Blaze Whole Device: passo 2, imagem 1 %32
    • Remove the battery from the device.
  3. Disassembling Samsung Galaxy S Blaze Whole Device: passo 3, imagem 1 %32 Disassembling Samsung Galaxy S Blaze Whole Device: passo 3, imagem 2 %32
    • Use a Phillips head screwdriver size 00.
    • Remove the 4mm screws from the frame.
    • The eight screws are all the same size.
  4. Disassembling Samsung Galaxy S Blaze Whole Device: passo 4, imagem 1 %32
    • Remove the frame from the phone by using the blue plastic opening tool.
    • Work around the phone with the tool until the frame is off.
    • You may need to use a bit of force to pry off the frame.
  5. Disassembling Samsung Galaxy S Blaze Whole Device: passo 5, imagem 1 %32
    • The volume rocker is attached to the frame by two plastic prongs.
    • Unhook the prongs from the frame and remove the volume rocker.
  6. Disassembling Samsung Galaxy S Blaze Whole Device: passo 6, imagem 1 %32
    • The SD card slot is held in place by a small tab.
    • Unhook the tab of the SD card slot from the frame of the phone.
  7. Disassembling Samsung Galaxy S Blaze Whole Device: passo 7, imagem 1 %32
    • The power button is attached to the phone with two prongs.
    • Unhook the prongs of the power button from the frame of the phone.
  8. Disassembling Samsung Galaxy S Blaze Whole Device: passo 8, imagem 1 %32 Disassembling Samsung Galaxy S Blaze Whole Device: passo 8, imagem 2 %32 Disassembling Samsung Galaxy S Blaze Whole Device: passo 8, imagem 3 %32
    • 4 ribbon cable connectors hold the motherboard to the phone.
    • The first 3 are all on one side.
    • Use the blue plastic opening tool to unlatch the wire ribbons from the motherboard.
  9. Disassembling Samsung Galaxy S Blaze Whole Device: passo 9, imagem 1 %32
    • Flip the motherboard over to access the last ribbon cable connector.
    • Unlatch the final ribbon cable connector from the phone.
    • Remove the motherboard from the phone.
  10. Disassembling Samsung Galaxy S Blaze Whole Device: passo 10, imagem 1 %32
    • All of the parts are seen here.
Conclusão
If there is something wrong with your device, try this: Samsung Galaxy S Blaze 4G Troubleshooting
Jake Best
Membro desde: 03/05/15
261 Reputação
Autoria de 2 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 5
Duração total: 728
