Ir para o conteúdo principal
Disassembling Samsung Galaxy Ace Logic Board
O que você precisa
  1. Disassembling Samsung Galaxy Ace Logic Board, Logic Board: passo 1, imagem 1 %32 Disassembling Samsung Galaxy Ace Logic Board, Logic Board: passo 1, imagem 2 %32
    • Remove the battery cover and the battery
  2. Disassembling Samsung Galaxy Ace Logic Board: passo 2, imagem 1 %32 Disassembling Samsung Galaxy Ace Logic Board: passo 2, imagem 2 %32
    • Remove the 7 silver screws with a Phillips #000 screw driver.
    • Sometimes the green one could be a little difficult. Use a tweezer for get it out.
  3. Disassembling Samsung Galaxy Ace Logic Board: passo 3, imagem 1 %32 Disassembling Samsung Galaxy Ace Logic Board: passo 3, imagem 2 %32 Disassembling Samsung Galaxy Ace Logic Board: passo 3, imagem 3 %32
    • Lift gently the back cover from the screen assembly from the bottom.
  4. Disassembling Samsung Galaxy Ace Logic Board: passo 4, imagem 1 %32 Disassembling Samsung Galaxy Ace Logic Board: passo 4, imagem 2 %32
    • Use a flat tweezer for take off the flexible on/off button from the frame.
    • Be careful, the flexible is very delicate; it could be cut if you go too fast.
  5. Disassembling Samsung Galaxy Ace Logic Board: passo 5, imagem 1 %32 Disassembling Samsung Galaxy Ace Logic Board: passo 5, imagem 2 %32 Disassembling Samsung Galaxy Ace Logic Board: passo 5, imagem 3 %32
    • Use a flat tweezer and take off gently Flexible volume button from the left side.
    • Do the same for the right side.
    • Then lift the flex slowly, if you go fast you may cut the cable.
  6. Disassembling Samsung Galaxy Ace Logic Board: passo 6, imagem 1 %32
    • Lift the microphone from the logic board.
  7. Disassembling Samsung Galaxy Ace Logic Board: passo 7, imagem 1 %32 Disassembling Samsung Galaxy Ace Logic Board: passo 7, imagem 2 %32 Disassembling Samsung Galaxy Ace Logic Board: passo 7, imagem 3 %32
    • Lift the sensor/earpiece cable with the opening tool.
    • Don't force, you may damage the soldering.
  8. Disassembling Samsung Galaxy Ace Logic Board: passo 8, imagem 1 %32 Disassembling Samsung Galaxy Ace Logic Board: passo 8, imagem 2 %32 Disassembling Samsung Galaxy Ace Logic Board: passo 8, imagem 3 %32
    • Lift the logic board from the right side.
    • Use the removal tool to unplug the display cable from the logic board.
    • You can now separate the Logic board from the display assembly.
  9. Disassembling Samsung Galaxy Ace Logic Board: passo 9, imagem 1 %32 Disassembling Samsung Galaxy Ace Logic Board: passo 9, imagem 2 %32
    • Use the removal tool to unclip the camera module from the Logic board.
  10. Disassembling Samsung Galaxy Ace Logic Board: passo 10, imagem 1 %32 Disassembling Samsung Galaxy Ace Logic Board: passo 10, imagem 2 %32 Disassembling Samsung Galaxy Ace Logic Board: passo 10, imagem 3 %32
    • Use the removal tool or a spudger to unplug speaker module cable
    • And separate the speaker module from Logic board.
    • Be caution, the module is fixed by plastic teeth to the Logic board. Don't force, just make little wave-movements and the speaker comes on his own.
  11. Disassembling Samsung Galaxy Ace Logic Board: passo 11, imagem 1 %32
    • Now you can work with the Logic board.
Conclusão
34 outras pessoas executaram este guia.
finster
Membro desde: 08/17/11
1.986 Reputação
Autoria de 1 guia
2 comentários
Thanks for the post. This is really Helpful
Dave Dayanan - Responder
im curently selling one thx to you
Kyle at work - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 22
Duração total: 26,764
