Introdução
This is the first few steps for disassembling the DVD player.
Peças
Não são necessárias peças.
  1. Open the tray by pressing the eject button Remove the DVD tray faceplate by pushing the faceplate up off of the tray. Remove the DVD tray faceplate by pushing the faceplate up off of the tray.
    • Open the tray by pressing the eject button
    • Remove the DVD tray faceplate by pushing the faceplate up off of the tray.
  2. Press the eject button to insert the tray
    • Press the eject button to insert the tray
    • After the tray is closed unplug DVD player
  3. Free shipping on all orders over US$100 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  4. Unscrew the 3 screws in the back.
    • Unscrew the 3 screws in the back.
  5. Pull the outer case upward and then towards you. Pull the outer case upward and then towards you.
    • Pull the outer case upward and then towards you.
  6. There are six symmetrically placed tabs holding in the front faceplate.  Unhook these six tabs to loosen the faceplate. There are six symmetrically placed tabs holding in the front faceplate.  Unhook these six tabs to loosen the faceplate. There are six symmetrically placed tabs holding in the front faceplate.  Unhook these six tabs to loosen the faceplate.
    • There are six symmetrically placed tabs holding in the front faceplate. Unhook these six tabs to loosen the faceplate.
  7. Pull off front faceplate. This may take a couple of tries to get all six tabs unhooked simultaneously. Pull off front faceplate. This may take a couple of tries to get all six tabs unhooked simultaneously.
    • Pull off front faceplate. This may take a couple of tries to get all six tabs unhooked simultaneously.
Conclusão
3 outras pessoas concluíram este guia.
Mitchell Hart
834 reputação
5 Guides authored
Equipe
Cal Poly, Team 3-30, Regan Winter 2011 Membro de Cal Poly, Team 3-30, Regan Winter 2011
CPSU-REGAN-W11S3G30
4 Membros
8 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Todo: 2,336
