Ir para o conteúdo principal
Disassembling SKIL 4235 Jigsaw Protective Frame
Pré-requisito somente
Este guia destina-se apenas a ser usado como pré-requisito para outros guias. É incompleto por si só.
O que você precisa
  1. Disassembling SKIL 4235 Jigsaw Protective Frame, Protective Frame: passo 1, imagem 1 %32 Disassembling SKIL 4235 Jigsaw Protective Frame, Protective Frame: passo 1, imagem 2 %32 Disassembling SKIL 4235 Jigsaw Protective Frame, Protective Frame: passo 1, imagem 3 %32
    • Ensure that the Jigsaw is properly placed and that the blade is away from your body with the screws facing upward.
    • Identify the 10 screws circled for removal. Once all screws have been identified, use your Phillips screwdriver and begin removing them.
    • Once all screws have been removed, remove the protective frame by gripping it from both sides and lifting it skyward.
    • Be advised
    • You may need to lift with one hand and hold the rest of the saw with the other.
    • Now placing the frame off to the side you should have a clear view of all the internal working parts. Now we can begin making our repairs.
Conclusão
Adam Cardoso
Membro desde: 11/12/13
357 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 4-8, Vijaybhaskar Fall 2013 Membro de UMass Dartmouth, Team 4-8, Vijaybhaskar Fall 2013
UMASSD-VIJAYBHASKAR-F13S4G8
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 155
