Ir para o conteúdo principal
Disassembling Qualcomm QCP-2760 Rear Backing
O que você precisa
  1. Disassembling Qualcomm QCP-2760 Rear Backing, Battery: passo 1, imagem 1 %32
    • Unscrew the back battery plate from the phone using a T6 Torx screwdriver.
    • The screw does not need to be removed completely, the back battery plate will unhinge from the phone.
  2. Disassembling Qualcomm QCP-2760 Rear Backing, Rear Backing: passo 2, imagem 1 %32 Disassembling Qualcomm QCP-2760 Rear Backing, Rear Backing: passo 2, imagem 2 %32
    • Using the T6 Torx screwdriver, remove the two screws located at the bottom of the back of the phone.
    • Find the seam between the front and back of the phone
    • Pry the seam open using a plastic opening tool, or your fingers.
    • Some force is required
Conclusão
Xavier
Membro desde: 10/02/14
313 Reputação
Autoria de 3 guias
Equipe
Ohio State, Team 1-4, Buehl Fall 2014 Membro de Ohio State, Team 1-4, Buehl Fall 2014
OSU-BUEHL-F14S1G4
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 215
