Ir para o conteúdo principal
Disassembling Power Mac G4 M5183 DVD-ROM Drive
O que você precisa
  1. Disassembling Power Mac G4 M5183 DVD-ROM Drive, Opening PowerMac G4 M5183 Case: passo 1, imagem 1 %32 Disassembling Power Mac G4 M5183 DVD-ROM Drive, Opening PowerMac G4 M5183 Case: passo 1, imagem 2 %32
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
    Pergunte ao FixBot
    Comentar
  2. Disassembling Power Mac G4 M5183 DVD-ROM Drive, DVD-ROM Drive: passo 2, imagem 1 %32 Disassembling Power Mac G4 M5183 DVD-ROM Drive, DVD-ROM Drive: passo 2, imagem 2 %32
    • Removing the faceplate.
    • On the inside of the case, find the two plastic tabs.
    • While depressing the tabs, remove the faceplate by pulling and rotating outward.
    Pergunte ao FixBot
    Comentar
  3. Disassembling Power Mac G4 M5183 DVD-ROM Drive: passo 3, imagem 1 %32
    • Remove the two screws on the front of the drive with the Phillips #1 screwdriver.
    Pergunte ao FixBot
    Comentar
  4. Disassembling Power Mac G4 M5183 DVD-ROM Drive: passo 4, imagem 1 %32 Disassembling Power Mac G4 M5183 DVD-ROM Drive: passo 4, imagem 2 %32 Disassembling Power Mac G4 M5183 DVD-ROM Drive: passo 4, imagem 3 %32
    • Pull the drive out to allow access to the power and ribbon cables. Do not fully remove.
    • Remove both the power and ribbon cable.
    Pergunte ao FixBot
    Comentar
  5. Disassembling Power Mac G4 M5183 DVD-ROM Drive, DVD-ROM Drive: passo 5, imagem 1 %32 Disassembling Power Mac G4 M5183 DVD-ROM Drive, DVD-ROM Drive: passo 5, imagem 2 %32 Disassembling Power Mac G4 M5183 DVD-ROM Drive, DVD-ROM Drive: passo 5, imagem 3 %32
    • Remove DVD drive from the drive bay.
    • Lift the two metal tabs on the back of the shielding and remove.
    • Remove the four screws on the bottom of the drive with the Phillips #1 screwdriver.
    • Slide out DVD drive.
    Pergunte ao FixBot
    Comentar
Conclusão
12 outras pessoas executaram este guia.
Stephen Scruggs
Membro desde: 01/20/10
2.283 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 13-24, Maness Winter 2010 Membro de Cal Poly, Team 13-24, Maness Winter 2010
CPSU-MANESS-W10S13G24
4 Membros
Autoria de 37 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 18
Últimos 30 dias: 76
Ao todo: 12,175
