Introdução
It is the first step in repairing the internal components of the cube.
O que você precisa
Release the back handle of the PowerMac. Slowly pull out the cube by holding the end of the handle. Watch for any parts that may become entangled with the outer case.
Push back the handle after you have taken the core out of the case.
8 outras pessoas executaram este guia.
1Comentário do guia
This does not describe the disassembly of the outer case! Just how to remove the inter case. If you need to clean the outer case this instruction is of no use.
