Ir para o conteúdo principal
Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide)
O que você precisa
Vídeo de Apresentação
  1. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide), Case Separation: passo 1, imagem 1 %32 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide), Case Separation: passo 1, imagem 2 %32
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): passo 2, imagem 1 %32 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): passo 2, imagem 2 %32 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): passo 2, imagem 3 %32
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): passo 3, imagem 1 %32 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): passo 3, imagem 2 %32
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): passo 4, imagem 1 %32 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): passo 4, imagem 2 %32 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): passo 4, imagem 3 %32
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): passo 5, imagem 1 %32 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): passo 5, imagem 2 %32
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): passo 6, imagem 1 %32
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): passo 7, imagem 1 %32
    • Free the battery cable by gently prying up on the connection with a spudger.
  8. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): passo 8, imagem 1 %32
    • Separate the front and rear cases.
  9. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide), Battery: passo 9, imagem 1 %32 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide), Battery: passo 9, imagem 2 %32
    • With the help of a spudger, gently pry off and remove the battery cable retainer on the back casing assembly.
    • The easiest access to the battery cable retainer is where the battery cable comes out.
    • You can also use the two small tabs on the side of the cable retainer. Locate the tabs and release one at a time. Be a little careful not to push the cover in and re-lock it.
  10. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): passo 10, imagem 1 %32 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): passo 10, imagem 2 %32
    • Using a Phillips #00 screwdriver, remove the two 5.0mm blue battery case screws.
    • Remove the plastic battery retaining bar.
  11. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): passo 11, imagem 1 %32 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): passo 11, imagem 2 %32 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): passo 11, imagem 3 %32
    • Using your finger or a spudger, lift the battery out and remove it.
    • Guide the battery wires through the hole in the back casing as you remove the battery.
Conclusão
6 outras pessoas executaram este guia.
djgodmandj
Membro desde: 10/24/14
284 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 30
Duração total: 5,682
