Ir para o conteúdo principal
Disassembling Philips Portable Speaker SBA1610 37 Battery Casing
O que você precisa
  1. Disassembling Philips Portable Speaker SBA1610 37 Battery Casing, Battery Casing: passo 1, imagem 1 %32
    • Remove the back cover by sliding it off.
    • Remove the 3 AAA batteries.
  2. Disassembling Philips Portable Speaker SBA1610 37 Battery Casing: passo 2, imagem 1 %32 Disassembling Philips Portable Speaker SBA1610 37 Battery Casing: passo 2, imagem 2 %32 Disassembling Philips Portable Speaker SBA1610 37 Battery Casing: passo 2, imagem 3 %32
    • Unscrew the nine exterior screws on the back panel using a PH0-size Philips-head screwdriver.
    • A larger screwdriver head and more force may be required for damaged screws.
    • Remove the triangular end piece by pulling it straight off.
  3. Disassembling Philips Portable Speaker SBA1610 37 Battery Casing: passo 3, imagem 1 %32 Disassembling Philips Portable Speaker SBA1610 37 Battery Casing: passo 3, imagem 2 %32
    • Remove the colored grill by sliding it off in the direction of the removed end piece.
    • Pry off the back battery panel with the plastic opening tool.
    • Be careful to avoid tearing any wires.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Clemson, Team 14-4, Benson Fall 2013 Membro de Clemson, Team 14-4, Benson Fall 2013
CLEM-BENSON-F13S14G4
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 15
Duração total: 4,718
