Ir para o conteúdo principal
Disassembling Pentax PZ-10 Top Cover
O que você precisa
  1. Disassembling Pentax PZ-10 Top Cover, Top Cover: passo 1, imagem 1 %32
    • The top cover is one piece encasing the top of the device except the shutter release button and flash.
  2. Disassembling Pentax PZ-10 Top Cover, Removing Upper Right Housing Screw: passo 2, imagem 1 %32 Disassembling Pentax PZ-10 Top Cover, Removing Upper Right Housing Screw: passo 2, imagem 2 %32
    • With the camera lens face down, locate the screw under the overhanging piece of the top casing on the right side of the back panel.
    • Using the J0 screwdriver, remove the 6.3 mm screw.
  3. Disassembling Pentax PZ-10 Top Cover, Removing Screw in Battery Compartment: passo 3, imagem 1 %32 Disassembling Pentax PZ-10 Top Cover, Removing Screw in Battery Compartment: passo 3, imagem 2 %32
    • Locate the next screw by holding the camera upside down with the battery compartment empty and face up.
    • Remove the 6.3 mm screw using a J0 screwdriver.
  4. Disassembling Pentax PZ-10 Top Cover, Removing Screw Under Flash Bulb: passo 4, imagem 1 %32 Disassembling Pentax PZ-10 Top Cover, Removing Screw Under Flash Bulb: passo 4, imagem 2 %32
    • The next screw is found in the overhanging piece just above the lens.
    • With the top of the camera facing down, remove the 3.4 mm screw with a J0 screwdriver.
  5. Disassembling Pentax PZ-10 Top Cover, Pulling Off the Top Cover: passo 5, imagem 1 %32 Disassembling Pentax PZ-10 Top Cover, Pulling Off the Top Cover: passo 5, imagem 2 %32
    • Gently pull off the top cover with your hands by pulling on the tab on the left of the camera.
Conclusão
Jonathan Diaz
Membro desde: 04/20/15
213 Reputação
Autoria de 2 guias
Um comentário
Thank you! Well done sir!
michaelsteele1953 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 928
