Ir para o conteúdo principal
Disassembling Pentax K200D Front Cover
O que você precisa
  1. Disassembling Pentax K200D Front Cover, Preparation: passo 1, imagem 1 %32
    • Retrieve your Pentax K200D, the lens mount cover, and required tools.
    • Remove the lens, if you have one attached, and replace it with the lens mount cover to make handling and repair easier.
  2. Disassembling Pentax K200D Front Cover, Flash: passo 2, imagem 1 %32
    • With the camera turned on, press the pop-up flash button to release the flash.
    • Be sure to turn the camera back off before proceeding.
    • Remove the two 4.3 mm Phillips screws securing the top edge of the front cover to the top cover.
  3. Disassembling Pentax K200D Front Cover, Bottom cover: passo 3, imagem 1 %32
    • Remove the seven 4.3 mm Phillips screws securing the bottom cover to the camera body
    • Remove the two 2.5 mm Phillips screws also securing the bottom cover to the camera body
    • Open the battery door and carefully remove the bottom cover, as the battery door components become unsecured when the bottom cover is removed.
  4. Disassembling Pentax K200D Front Cover: passo 4, imagem 1 %32
    • Remove the two 4.3 mm Phillips screws securing the right side of the front cover to the camera body.
Conclusão
9 outras pessoas executaram este guia.
Rick Nelson
Membro desde: 06/05/10
706 Reputação
Autoria de 1 guia
Equipe
Master Techs Membro de Master Techs
Community
329 Membros
Autoria de 1.452 guias
1Comentário do guia
How do l clean the prisum…
brett_lorking - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 57
Ao todo: 7,257
