Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Remove the four rubber screw covers from encircled locations.
Using a #0 tri wing screwdriver, remove the screws previously hidden below the rubber covers.
If you have difficulties finding this screwdriver, it is commonly sold as a Nintendo Gameboy/Wii screwdriver.
Pry the case open using iPhone tool (as shown), fingernails, small flathead screwdriver, etc.
Be mindful of location and magnitude of applied force, so as not to damage the case.
Unlock the minor LCD connector by applying bilateral pressure with tweezers, as shown.
Use fingernails to pry off minor LCD mount, as shown.
Remove the minor LCD
Unlock the LCD connectors shown in red boxes on the picture .
Use tweezers as necessary.
Place finger nails on the connector tab as shown.
Lift the connector tab up.
Pull/pivot the LCD main board as shown in order to remove.
