Ir para o conteúdo principal
Disassembling Panasonic GU87 Main-LCD
O que você precisa
  1. Disassembling Panasonic GU87 Main-LCD, LCD Cover removal: passo 1, imagem 1 %32
    • Remove the four rubber screw covers from encircled locations.
    • Using a #0 tri wing screwdriver, remove the screws previously hidden below the rubber covers.
    • If you have difficulties finding this screwdriver, it is commonly sold as a Nintendo Gameboy/Wii screwdriver.
  2. Disassembling Panasonic GU87 Main-LCD: passo 2, imagem 1 %32
    • Pry the case open using iPhone tool (as shown), fingernails, small flathead screwdriver, etc.
    • Be mindful of location and magnitude of applied force, so as not to damage the case.
  3. Disassembling Panasonic GU87 Main-LCD, LCD: passo 3, imagem 1 %32
    • Unlock the minor LCD connector by applying bilateral pressure with tweezers, as shown.
  4. Disassembling Panasonic GU87 Main-LCD: passo 4, imagem 1 %32
    • Use fingernails to pry off minor LCD mount, as shown.
    • Remove the minor LCD
  5. Disassembling Panasonic GU87 Main-LCD, Main Board: passo 5, imagem 1 %32
    • Unlock the LCD connectors shown in red boxes on the picture .
    • Use tweezers as necessary.
  6. Disassembling Panasonic GU87 Main-LCD: passo 6, imagem 1 %32
    • Place finger nails on the connector tab as shown.
    • Lift the connector tab up.
  7. Disassembling Panasonic GU87 Main-LCD: passo 7, imagem 1 %32
    • Pull/pivot the LCD main board as shown in order to remove.
  8. Disassembling Panasonic GU87 Main-LCD, Disassembling Panasonic GU87 Main-LCD: passo 8, imagem 1 %32
    • Use tweezers to lift up the main LCD.
Conclusão
Van
Membro desde: 06/24/10
7 Reputação
Autoria de 8 guias
Equipe
Cal Poly, Team 2-10, Johann Summer 2010 Membro de Cal Poly, Team 2-10, Johann Summer 2010
CPSU-JOHANN-R10S2G10
Membros da 4
Autoria de 20 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 1,201
