Ir para o conteúdo principal
Disassembling Panasonic GU87 Main Board removal
O que você precisa
  1. Disassembling Panasonic GU87 Main Board removal, Battery: passo 1, imagem 1 %32
    • Place your hands on the phone as shown in picture. Slightly pull the tab away from the phone with your thumb.
  2. Disassembling Panasonic GU87 Main Board removal: passo 2, imagem 1 %32
    • Lift the battery up from the phone as shown. Replace with a new battery if the old battery has become worn out.
  3. Disassembling Panasonic GU87 Main Board removal, Disassembling Panasonic GU87 Back cover: passo 3, imagem 1 %32
    • Remove the rubber covers with tweezers.
  4. Disassembling Panasonic GU87 Main Board removal: passo 4, imagem 1 %32
    • Remove all 4 screws from the back of the phone.
  5. Disassembling Panasonic GU87 Main Board removal: passo 5, imagem 1 %32
    • Use a plastic opening tool to separate the front and back casing.
  6. Disassembling Panasonic GU87 Main Board removal: passo 6, imagem 1 %32
    • Put the tool in friction tabs and force down to open the cover as shown in the picture.
    • Carefully pop it open the rest of the way with your fingers.
  7. Disassembling Panasonic GU87 Main Board removal, Disassembling Panasonic GU87 Main Board removal: passo 7, imagem 1 %32
    • Lift the main board over.
  8. Disassembling Panasonic GU87 Main Board removal: passo 8, imagem 1 %32
    • Pry the connector with finger nails.
Conclusão
Van
Membro desde: 06/24/10
7 Reputação
Autoria de 8 guias
Equipe
Cal Poly, Team 2-10, Johann Summer 2010 Membro de Cal Poly, Team 2-10, Johann Summer 2010
CPSU-JOHANN-R10S2G10
Membros da 4
Autoria de 20 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 1,743
