Ir para o conteúdo principal
Disassembling Palm Centro Logic Board
O que você precisa
  1. Disassembling Palm Centro Logic Board, Disassembling Palm Centro Battery: passo 1, imagem 1 %32 Disassembling Palm Centro Logic Board, Disassembling Palm Centro Battery: passo 1, imagem 2 %32
    • Press and slide open the battery cover.
  2. Disassembling Palm Centro Logic Board: passo 2, imagem 1 %32
    • Caution: Turn cell phone off before removing battery!
    • Press battery to the right.
    • Then lift up battery pack to remove.
  3. Disassembling Palm Centro Logic Board: passo 3, imagem 1 %32
    • Phone with battery removed
  4. Disassembling Palm Centro Logic Board, Back Housing: passo 4, imagem 1 %32
    • Remove the touchpad pen from the top left corner on the back to reveal the last of 6 screws to be removed.
  5. Disassembling Palm Centro Logic Board: passo 5, imagem 1 %32
    • Lift the rubber cap at the top right to reveal the sixth screw.
    • Caution: There is a small Palm sticker under the rubber cap. Tampering with or removing this sticker will void your warranty!
    • Remove the six screws using the T5 Torx screwdriver.
  6. Disassembling Palm Centro Logic Board: passo 6, imagem 1 %32 Disassembling Palm Centro Logic Board: passo 6, imagem 2 %32
    • Remove the SIM card so housing can be separated.
  7. Disassembling Palm Centro Logic Board: passo 7, imagem 1 %32 Disassembling Palm Centro Logic Board: passo 7, imagem 2 %32
    • Use a plastic pry tool to separate the bottom of the case to remove the small plastic insert.
  8. Disassembling Palm Centro Logic Board: passo 8, imagem 1 %32 Disassembling Palm Centro Logic Board: passo 8, imagem 2 %32
    • Remove the small plastic insert at the bottom of the phone.
  9. Disassembling Palm Centro Logic Board: passo 9, imagem 1 %32 Disassembling Palm Centro Logic Board: passo 9, imagem 2 %32
    • Continue with plastic pry tool all the way around the phone to remove the back housing.
  10. Disassembling Palm Centro Logic Board, Logic Board: passo 10, imagem 1 %32
    • Carefully peel back the tape holding the speaker (left) and keyboard (right) connection tabs in place.
  11. Disassembling Palm Centro Logic Board: passo 11, imagem 1 %32
    • Using the plastic prying tool, lift the tabs and carefully pull the contact connections out on both sides.
    • Be very careful, these electronics are delicate!
  12. Disassembling Palm Centro Logic Board: passo 12, imagem 1 %32
    • Separate the logic board from the case by lifting and pulling out the bottom.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team 15-49, Garner Spring 2010 Membro de Cal Poly, Team 15-49, Garner Spring 2010
CPSU-GARNER-S10S15G49
Membros da 5
Autoria de 12 guias
2 comentários
note: if you need to replace the logic board, follow this guide, insert a new board, and then follow the steps in reverse order to get a working phone.
Chelsea Barackman - Responder
i try to on this mobile ..but cant do that, i try to on this mobile so many ways.. i want to whhy thi mobile not on and how to resolve it?
kelumaruna - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 19
Duração total: 3,123
