Ir para o conteúdo principal
Disassembling Olympus Stylus Tough-8010 Camera Casing
O que você precisa
  1. Disassembling Olympus Stylus Tough-8010 Camera Casing, Camera Casing: passo 1, imagem 1 %32 Disassembling Olympus Stylus Tough-8010 Camera Casing, Camera Casing: passo 1, imagem 2 %32 Disassembling Olympus Stylus Tough-8010 Camera Casing, Camera Casing: passo 1, imagem 3 %32
    • Remove the front three screws (3.2mm) using a type T-6 head screwdriver.
    • Take off smaller front cover.
    • Carefully remove larger front cover.
  2. Disassembling Olympus Stylus Tough-8010 Camera Casing: passo 2, imagem 1 %32 Disassembling Olympus Stylus Tough-8010 Camera Casing: passo 2, imagem 2 %32 Disassembling Olympus Stylus Tough-8010 Camera Casing: passo 2, imagem 3 %32
    • Remove two screws (4.1mm) on the top of the camera using a #000 Phillips head screwdriver.
    • Using a #000 Phillips head screwdriver remove two screws (7.9mm) near the control panel and set aside the metal connector.
    • Although the third photo shows the side panel casing being removed, it is normally secured by a screw under the front framework. You'll need to follow the next two steps to remove the framework and access the screw before you can remove the side casing as shown here.
  3. Disassembling Olympus Stylus Tough-8010 Camera Casing: passo 3, imagem 1 %32 Disassembling Olympus Stylus Tough-8010 Camera Casing: passo 3, imagem 2 %32 Disassembling Olympus Stylus Tough-8010 Camera Casing: passo 3, imagem 3 %32
    • Using a #000 Philips head screwdriver remove the two screws (4.1mm) on the right side of the camera.
    • Remove two screws (4.1mm) on the bottom of the camera using a #000 head Phillips screwdriver.
    • Remove the single screw (3.2mm) on the front of the camera using a #000 Phillips head.
  4. Disassembling Olympus Stylus Tough-8010 Camera Casing: passo 4, imagem 1 %32 Disassembling Olympus Stylus Tough-8010 Camera Casing: passo 4, imagem 2 %32
    • Carefully remove the font panel piece from the rest of the camera.
    • Carefully remove the top/side plastic piece.
    • If the the camera and flash buttons fall out of their slots set them aside.
    • If you haven't already done so, remove the side casing as mentioned in Step 3. It is secured by a single screw near the bottom corner.
  5. Disassembling Olympus Stylus Tough-8010 Camera Casing: passo 5, imagem 1 %32 Disassembling Olympus Stylus Tough-8010 Camera Casing: passo 5, imagem 2 %32 Disassembling Olympus Stylus Tough-8010 Camera Casing: passo 5, imagem 3 %32
    • Remove four screws (9.4mm) on the front of the camera using a Phillips #000
    • Use the plastic opening tool to release the holding clip.
    • Using tweezers separate the plastic strips from their connectors located on the main circuit board by lifting the small, black flaps on the connectors and pulling on the ribbons.
Conclusão
3 outras pessoas executaram este guia.
Luke Visser
Membro desde: 03/23/15
476 Reputação
Autoria de 4 guias
Equipe
Baylor, Team 7-15, Williams Spring 2015 Membro de Baylor, Team 7-15, Williams Spring 2015
BU-WILLIAMS-S15S7G15
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 11
Duração total: 870
