Ir para o conteúdo principal
Disassembling Olympus Stylus Tough 6020 Prerequisite Guide
O que você precisa
  1. Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Battery: passo 1, imagem 1 %32
    • Slide and push the battery casing to open it.
    • Push the battery to eject it.
  2. Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Bottom Plating: passo 2, imagem 1 %32 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Bottom Plating: passo 2, imagem 2 %32 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Bottom Plating: passo 2, imagem 3 %32
    • Turn the camera so that you are facing the bottom of the camera.
    • Using a Phillips 00 screwdriver, unscrew the three 3.9mm screws on the bottom of the camera.
    • Using a spudger, pry off the plating on the bottom of the camera.
  3. Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Top Plating: passo 3, imagem 1 %32 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Top Plating: passo 3, imagem 2 %32 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Top Plating: passo 3, imagem 3 %32
    • Turn the camera so that you are facing the top of the camera.
    • Using a Phillips 00 screwdriver, unscrew the three 3.9mm screws located on the top of the camera.
    • Using a spudger, pry off the plating on the top of the camera.
  4. Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Left Plating: passo 4, imagem 1 %32 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Left Plating: passo 4, imagem 2 %32
    • Turn the camera so the LCD is facing upwards.
    • Using a Phillips 00 screwdriver, unscrew the two 3.9mm screws located on the left side of the device.
  5. Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Black "Olympus" Face Plate: passo 5, imagem 1 %32 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Black "Olympus" Face Plate: passo 5, imagem 2 %32 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Black "Olympus" Face Plate: passo 5, imagem 3 %32
    • Using a Phillips 00 screwdriver, unscrew the 3.9mm screw located next to the black "Olympus" face plate.
    • Using a T6 Torx screwdriver, unscrew the two 3.5mm screws located on the black "Olympus" face plate.
    • Using a spudger, gently pry off the black "Olympus" face plate.
  6. Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, End Casing: passo 6, imagem 1 %32 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, End Casing: passo 6, imagem 2 %32 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, End Casing: passo 6, imagem 3 %32
    • Using a Phillips 00 screwdriver, unscrew the two 3.9mm screws to the right of the cursor pad on the U-shaped frame.
    • Turn the device over so the front of the camera is facing you.
    • Using a Phillips 00 screwdriver, unscrew the two 3.9mm screws on the end casing.
    • Using a spudger, pry off the end casing.
  7. Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Blue Face Plate: passo 7, imagem 1 %32 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Blue Face Plate: passo 7, imagem 2 %32 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Blue Face Plate: passo 7, imagem 3 %32
    • Turn the camera so the blue face plate is visible.
    • Using a Phillips 00 screwdriver, unscrew the two 3mm screws on the blue plate.
    • Using a Phillips 00 screwdriver, unscrew the 3.9mm screw located at the bottom of the camera straight down from the flash.
    • Using a spudger, gently pry off the blue face plate.
  8. Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Back Plate: passo 8, imagem 1 %32
    • Using a Phillips 00 screwdriver, unscrew the 9mm screws on the top of the camera to the right of the flash.
  9. Disassembling Olympus Stylus Tough 6020 Prerequisite Guide: passo 9, imagem 1 %32 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide: passo 9, imagem 2 %32 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide: passo 9, imagem 3 %32
    • Using a Phillips 00 screwdriver, unscrew the wide 3.5mm screw located in the middle of the camera.
    • Using a Phillips 00 screwdriver, unscrew the 9mm screw located at the top left corner of the camera.
    • Using a spudger, separate the black plate from the camera.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 707
