Ir para o conteúdo principal
Disassembling Olympus Stylus 725 SW Side Panels
O que você precisa
  1. Disassembling Olympus Stylus 725 SW Side Panels, Disassembling Olympus Stylus 725 SW Battery: passo 1, imagem 1 %32 Disassembling Olympus Stylus 725 SW Side Panels, Disassembling Olympus Stylus 725 SW Battery: passo 1, imagem 2 %32
    • The battery is located on the bottom of the camera.
    • Remove the battery by placing your thumb on the bottom flap and sliding the release button away from the side the lens is on. (The screwdriver is simply used as a reference point, no screws need to be removed)
    • If the battery is dead, charge it for 60-90 minutes.
    • When installing a charged battery, align the battery appropriately. The positive signs and negative should line up.
  2. Disassembling Olympus Stylus 725 SW Side Panels, Front Panel: passo 2, imagem 1 %32 Disassembling Olympus Stylus 725 SW Side Panels, Front Panel: passo 2, imagem 2 %32 Disassembling Olympus Stylus 725 SW Side Panels, Front Panel: passo 2, imagem 3 %32
    • Remove the top screws using a 1.5 mm screwdriver.
    • Remove the single side screw located on the side of the camera where the tab is, using a #00 screwdriver.
  3. Disassembling Olympus Stylus 725 SW Side Panels, Side Panels: passo 3, imagem 1 %32 Disassembling Olympus Stylus 725 SW Side Panels, Side Panels: passo 3, imagem 2 %32 Disassembling Olympus Stylus 725 SW Side Panels, Side Panels: passo 3, imagem 3 %32
    • Using a #00 Philips Head Screwdriver, remove the screws located on all four sides of the camera.
  4. Disassembling Olympus Stylus 725 SW Side Panels: passo 4, imagem 1 %32 Disassembling Olympus Stylus 725 SW Side Panels: passo 4, imagem 2 %32 Disassembling Olympus Stylus 725 SW Side Panels: passo 4, imagem 3 %32
    • After removing all four of the screws, pry the side covers off of the camera.
Conclusão
Bobby Hodges
Membro desde: 04/18/10
49 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 33-71, Johann Spring 2010 Membro de Cal Poly, Team 33-71, Johann Spring 2010
CPSU-JOHANN-S10S33G71
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 2,785
